Re: 656 diesel charging system
Posted by teddy52food on July 26, 2007 at 09:49:32 from (204.73.107.177):
In Reply to: 656 diesel charging system posted by CharlesS on July 26, 2007 at 08:53:34:
You may have a broken wire or loose connection in the rotor. I makes & breaks contact as the RPM changes.
