Re: front wheel bearings for SM.
Posted by ScottyHOMEy on July 26, 2007 at 16:04:23 from (70.105.246.111):
In Reply to: front wheel bearings for SM. posted by Floyd352 on July 26, 2007 at 15:30:45:
Is this by chance an after-market wide-front?
If so, and you can figure out what it is, chances are somebody here can get you going again.
If not, and even if the numbers are worn or gone, any good shop can measure up your bearings and races and figure out what you need.
