front wheel bearings for SM.
Posted by Floyd352 on July 26, 2007 at 15:30:45 from (70.101.125.60):
I bought a new set of wheel bearings for a Super M and found they don't even come close to fitting. Is it possible that I might have a front end from a 400? If so what size would the bearings be. My local dealer was less than helpful.They wouldn't order bearings for me on the chance they would fit. Has any one else had this problem? Could it be the model change over? I realy need a size on both the inner and outer bearing. thanks this is my most trustworthy tractor for hay cutting and light work.
