Re: front wheel bearings for SM.
Posted by Eastsider on July 26, 2007 at 21:15:25 from (24.111.77.43):
In Reply to: front wheel bearings for SM. posted by Floyd352 on July 26, 2007 at 15:30:45:
You shouldn"t have too much to worry about...there are two sizes of bearings that were used in the H/M series. My early ones use the smaller diameter ones, and those are probably the ones you have. I can"t give you the numbers, but go to the dealer and ask them to dig a little more...otherwise, call someone like Carter and Grunewald and they will fix you up....measure the old ones and give them the sizes.
