Behlen Road Gear on F20
Posted by ET on July 27, 2007 at 06:47:33 from (134.179.104.132):
I have recently finished the restoration of my wide front F20N. It is equiped with a behlen road gear. The seal on the input shaft leaks and it is a odd seal. It presses into the front cover and the rubber lip that contacts the yoke is quite long and cone shaped. Does anybody know a part number for this seal or where I can get one? Will a comon seal that matches the bore and shaft size work? I don't real want to pull the old seal out right now and destroy it because then I will be dead in the water without a replacement.
