Re: SOS I need help badly - starter elecrtical problem
Posted by old on July 28, 2007 at 13:45:35 from (4.245.3.137):
In Reply to: SOS I need help badly - starter elecrtical problem posted by 888 on July 28, 2007 at 12:32:21:
Is that the type of cub that has the motor/genny set up?? If it does I would pull it off and take it in and have it checked out. Those type are known to be a little on the weak side. Now if it has a normal starter again I would have it check and also clean all connections since 90% of the time a not start problem is from poor connections or a weak battery
