Re: SC Progress so far.
Posted by Idaho Ron on July 28, 2007 at 18:08:03 from (208.98.154.197):
In Reply to: Re: SC Progress so far. posted by georgeky on July 28, 2007 at 15:39:50:
I have one leak at one of the hoses going into the cylinder, the cylinder it's self does not leak out. But the leak that is the biggest is the valve at the pump. Neither one is leaking a lot but the touch valve is the worst.
Do you think I will need to rebuild the touch valve? Thanks Ron
