Re: 340 won't start
Posted by old on July 28, 2007 at 19:32:49 from (4.244.6.85):
In Reply to: 340 won't start posted by upred on July 28, 2007 at 19:24:04:
Check to see that you have voltage at the coil, ignition side. If you don't try a hot wire from the battery and see if it starts. If it does then you know the problem is from the coil back if it doesn't then you know its from the coil forward. Dirty points will not spark so you may need to clean the point and or replace them
