Re: Regular Clutch Removal
Posted by James Williams on July 28, 2007 at 19:39:56 from (74.46.209.180):
In Reply to: Regular Clutch Removal posted by Barry Ingraham on July 28, 2007 at 19:20:01:
Barry,As far as I am concerend its the best clutch there is.My regular was stuck bad we pryed them apart and sand blasted each plate.The front plate actually acts as a brake that stops the motion of the transmission.I had mine relined and it works as a brake for the tractor.I beleive you can replace it with a new style clutch and pressure plate.These clutches were designed to out last the tractor
jimmy
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
