Re: farmall H
Posted by Janicholson on July 29, 2007 at 13:06:45 from (66.173.50.7):
In Reply to: farmall H posted by sam in mo on July 29, 2007 at 12:50:23:
third party image
Hear is a very simple diagram, the parts are available at a Tractor friendly store. The hose into the top of the filler (using a new T fitting) can also be plumbed into the bottom grain plug with a T fitting. Use hydraulic qualified hoses, and an open center valve. Use a small clamp on the control rod to keep it from going in while using the system. good luck. JimN
