Re: Drippy F-12 fuel pump
Posted by James Williams on July 29, 2007 at 17:17:23 from (74.46.209.180):
In Reply to: Drippy F-12 fuel pump posted by Pete in Holland, MI on July 29, 2007 at 14:18:29:
Gary,F12 pumps are very simple,There are 2 different kinds,one has small square disc in them that are check valves.The most common are 2 brass check valves.Some of the pumps come with a diaphragm that can be replaced.others you need to order the more expensive kit that has a new diaphragm made on the shaft.Rice equipment has what you need.
jimmy 304-582-9995
