Re: Weight of international dozer
Posted by Haas on July 29, 2007 at 17:34:10 from (12.65.36.125):
In Reply to: Weight of international dozer posted by Marco54 on July 28, 2007 at 14:41:45:
I owned a TD-340 with 6 way blade for a short while. Easily hauled on a 14,000 lb goose neck trailer. The tractor alone is about 6000 lb as I recall with the 6 way blade adding another 1000 lbs or so. Don't know on the back hoe, but likely another 2000 for that so the total would be less than 10,000, still making it possible to haul on a gooseneck with an HD pickup.
