Re: Farmall B oil and coolant recommendations
Posted by ScottyHOMEy on July 30, 2007 at 08:52:06 from (70.105.246.111):
In Reply to: Farmall B oil and coolant recommendations posted by Dave H (MI) on July 30, 2007 at 07:43:23:
What's in the radiator now, Dave? I'd change it out, whatever it is, if only because it's likely been there a while. On my BN, I ran a batch of straight water for a while and it was picking up some rust, so I gave it one hot run with the washing soda mix that they talk about in the manual. Something like two pounds to 13 qts of water. Mix it well in buckets first before poring it into the radiator. Then run the engine hot. Since I don't have shutters on the BN, I just took a piece of newspaper and let the suction of the fan hold it to the grill. Ran it until it was good and hot. It was almost black when I drained it. I let it cool for a bit after I drained it, then refilled it with hot tap water. Ran that for a few days, drained it cold and let the hose water run right down through it for a few minutes, then refilled with 50-50 distilled water and plain old green anti-freeze. On the oil, we had a discussion here a while back about oil in old, unrebuilt engines. Basically, start out using straight 30 non-detergent oil. At each change add a quart of detergent oil in place of one of the non-detergent until after a few changes you're running detergent entirely. That's all to avid having a chunk of crud break loose all at once and plug something up. Once she's on a diet of regular oil, you can make your own choice about a multi-vis, especially if you have cold starting issues. The only place I'd stay with straight 30 is in the oil filler cup. I've found that 10-30, for example is too light and it gets sucked into the combustion air and will blow out through the ehaust a little. Going to straight 30 there solved that issue.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
