Re: Hydraulic pump kit
Posted by gene bender on July 30, 2007 at 16:50:40 from (67.55.226.214):
In Reply to: Hydraulic pump kit posted by Joe Kimbriel on July 30, 2007 at 14:28:59:
There is two types of seals that were used take your pump off then you will know which type you need along with a speedy sleeve if the shaft is worn. Any parts house can get the seal or o-ring which ever you need assuming that you have parts man and not a part time dummy.
