Re: Farmall C Timing Gear Question
Posted by Justin S. - TX on July 30, 2007 at 16:59:01 from (70.117.196.72):
In Reply to: Re: Farmall C Timing Gear Question posted by gene bender on July 30, 2007 at 04:37:06:
None of the timing set is turning, I removed as many bolts as i could on the timing cover and I can see all the way down to the crank shaft. When the crank shaft is turned, none of the timing set turns. Could the Woodruff key have sheared and cause the timing gear to spin? I can turn the timing set using a screwdriver and turn it gently with not much effort.
