Re: F-12 cam gear?
Posted by Wisbaker on July 31, 2007 at 15:19:49 from (72.160.196.238):
In Reply to: F-12 cam gear? posted by Farmall MD on July 31, 2007 at 14:47:18:
I may be wrong, but I'mthinking the cam gear turns the cam shaft at 1/2 the crank speed. If your timing mark is exactly 180 off it shouldn't make a difference. But what used to be the exhaust stroke would now be compression but the cam would operate the valves in time. Might have to install the mag 180 off or change wires
