Re: F-12 cam gear?
Posted by Farmall MD on July 31, 2007 at 16:34:11 from (152.163.98.54):
In Reply to: Re: F-12 cam gear? posted by Wisbaker on July 31, 2007 at 15:19:49:
Wisbaker, Yes, cam does turn at 1/2 speed as crank. I see what you're getting at, timing mag 180 off also. That should work, crank only knows up and down, it's the cam that determines compression, exhaust, or intake. As long as I time the mag at TDC compression, I should be ok.
Doug N
