Re: F-12 cam gear?
Posted by ET on August 01, 2007 at 05:15:41 from (134.179.104.132):
In Reply to: F-12 cam gear? posted by Farmall MD on July 31, 2007 at 14:47:18:
Why not line the two gears so the keyways are in line(you could even use a piece of straight key stock for perfect alignment). Then prick punch a new mark in the the repacment gear to match the old one.
