Rim Leak
Posted by Mapleguy on August 01, 2007 at 12:25:51 from (4.254.98.93):
The front rim on my Model 574 has an air leak where the center is rivetted to the outer ring. Is it necessary to replace the rim or just change from tubeless to tube? I am concerned that the loose rivets could cause further damage in future.I only use the tractor to mow waterways.
Thanks........
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
