Re: Rim Leak
Posted by old on August 01, 2007 at 13:47:20 from (4.244.218.97):
In Reply to: Rim Leak posted by Mapleguy on August 01, 2007 at 12:25:51:
Can not be sure on that tractor but most rims on most tractors are made to be run with tubes in them. So if that rim was made to have a tube then you should not be useing it tubeless or it can and will cause other problems. I know I have never seen a rim with rivits that where made to run tubeless
