Re: Lambert Disk brakes
Posted by Haas on August 01, 2007 at 12:49:02 from (12.65.78.216):
In Reply to: Re: Lambert Disk brakes posted by ChadS on July 31, 2007 at 09:52:50:
Maybe you can recut the spline. I would not know about that. However for the brakes to work properly, the splines must slide smoothly and easily on the shaft. If they do not, the brakes will not release properly. Also, the thickness of the disks with lining is critical for proper operation, as there is not much movement to the actuators and not a lot of adjustment either.
