Re: 966D TA
Posted by Kevin Meier on August 01, 2007 at 13:56:01 from (64.71.85.247):
In Reply to: 966D TA posted by Seeing Red on August 01, 2007 at 10:23:20:
You should check all of your hydraullic pressures first. I also found this info on a web site SLIPS ON HIGH SIDE (DD) OF TA. A. SELECTOR SPOOL NOT ADJUSTED PROPERLY. A. ADJUST SELECTOR SPOOL.
SPECIFICATION.
B. LOW OR LOSS OF CLUTCH PRESSURE. B. ADJUST CLUTCH PRESSURE TO CORRECT
C. DUMP VALVE STUCK OPEN OR MISADJUSTED C. CHECK OR ADJUST.
D. CLUTCH PACK WORN OUT. D. REPLACE TA.
I also have all parts you would need to replace the t/a if interested send me an email. Hope this helps.
