Re: Name this control
Posted by Mike CA on August 02, 2007 at 10:47:16 from (69.105.150.197):
In Reply to: Name this control posted by Wardner on August 02, 2007 at 07:39:48:
Wardner said: (quoted from post at 07:39:48 08/02/07) I have several of those valves. They are used on two or more single acting cylinders.
One application would be on cultivators where you wanted to lift one side but not the other. The center slot allows both sides to elevate at the same time.
The valve cannot be used on double acting cylinders without additional aftermarket valving.
Is it worth anything Wardner? I don't really believe I will be using it. Maybe someone around here could put it to work.
