Re: Need opinions of some wheels.
Posted by Steven@AZ on August 02, 2007 at 10:54:19 from (216.67.213.217):
In Reply to: Need opinions of some wheels. posted by Mike CA on August 02, 2007 at 00:45:39:
Mike, the rim you have pictured is toast... and beyond that - DANGEROUS! When they rust at the bead like that the tire can blow apart under a load or when adding air. Be very cautious around that until you let the air out of the tire!
I would go with the "take-off" set of wheels, tires, and rims. You will save the $$ of having the tires swapped over to different rims, and those tires look plenty useable. I believe new rims are closer to the $150 each range these days.
Happy to see you got an H! Keep updating us with progress pictures!
