Re: F20 oil pressure
Posted by Pete in Holland, MI on August 03, 2007 at 07:16:25 from (198.36.89.8):
In Reply to: F20 oil pressure posted by David F. Humphrey on August 02, 2007 at 11:59:59:
F-20's rely on splash lubrication for the connecting rods. It is NOT a pressurized crankshaft as in modern engines. A low pressure oil pump pulls oil from the sump, thru the filter, then down thru three external tubes to lube the forward & aft crank ball bearing, cam shaft gears, and also fill a galley that fills little banana-shaped trays under each lower connecting rod for the lower bearing cap to splash thru. Take one of the crank case covers off then start & idle the engine. You can see the system operating then. Not much oil will splash out at a slow idle. 10 psi is lots. Don't forget to oil the rocker arm tray each morning though!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
