Re: 1066 turbo won't go into reverse
Posted by rockwood84 on August 04, 2007 at 11:23:46 from (216.79.250.50):
In Reply to: Re: 1066 turbo won't go into reverse posted by rockwood84 on August 02, 2007 at 14:37:10:
mr. owen you were right the reverse fork was broke right below the shaft. one of the pads fell out when i took the side plate off had to look for the rest of it. and found it behind the side plate that has a pump on it. didn't want that stuff moving around and get in ring gears in the rear end. thanks again
