Re: 1066 turbo won't go into reverse
Posted by rockwood84 on August 02, 2007 at 14:37:10 from (216.79.252.190):
In Reply to: Re: 1066 turbo won't go into reverse posted by Owen Aaland on August 02, 2007 at 11:56:32:
thanks mr. owen for replying, it binds up down the vertical shaft that the has the splines on top of it. i tried to move the shaft and it will move about 1/4 inch. so its at the bottom of it where it is binding.i have not took the side plate off yet. still have some more hay to rake. but will take side plate off as soon as i get it raked thanks again
