Re: My fascination with the Mag
Posted by Janicholson on August 05, 2007 at 06:19:48 from (71.87.39.51):
In Reply to: My fascination with the Mag posted by Mike CA on August 05, 2007 at 00:00:39:
Mags are great for situations in which the operation of the tractor (or vehicle) needs to happen with or without a battery. Mags that were used on letter series (and earlier) were not able to provide one essential ingerdient, that is variable timing of the spark after startup. This factor alone would be the reason many were replaced. As the engine starts, at very slow crank speeds, the impulse coupling holds back mag rotation until TDC or a bit later. This allows the coupling a chance to windup a spring that releases causing the mags internal permanent magnet generator to make sufficient voltage to prep the mags coil for firing when the points break. The coupling is centrifugally controlled such that when the tractor starts, the impulse coupling is taken out of play, and the speed of the mag rotation is sufficient to make it spark as above. The timing is then advanced, due to the fact that the impulse coupling is not active, and is set (on these mags) at a advance useable at all (usually higher) engine speeds. Thus the mags timing is not able to adjust for Idle operations and points between. It is also not as flexible in total advance, because the ideal total high speed advance would be too great for the tractor to run well at idle. (and mag equipped tractors often do not idle well as it is) For a parade type tractor (not a trailer queen) I would keep the more satisfactory distributor setup. JimN
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
