Re: Voltage regulator question on H
Posted by Janicholson on August 05, 2007 at 07:49:19 from (71.87.39.51):
In Reply to: Voltage regulator question on H posted by Bob Kerr on August 05, 2007 at 07:33:54:
It is supposed to do that. A telling factor is voltage with it running at 3/4 throttle, and charging as described, put a volt meter across the battery. If it reads 14.2 to 14.6 volts, it is probably great. If it is in the 14.7 and above range, the regulator voltage is set high. This can be adjusted, but if under warrantee, I would take it back. The amp meter should go back to +4 or5 amps when an hour of operation has passed JimN
