Re: Farmall H Optional Lower 1st gear
Posted by CNKS on August 06, 2007 at 05:41:28 from (204.249.178.32):
In Reply to: Farmall H Optional Lower 1st gear posted by FarmallHPuller on August 05, 2007 at 20:25:20:
You will need the sliding gear and the countershaft gear (someone correct my terminology). Likely available only from salvage, unless you can find the tractor; they are not common. The speed of 2nd is not affected. IH only produced a high 4th and a low first, no other gears were affected. Come to think of it, I believe what you want is the low-reverse combination. Look up the part mumbers and diagram at www.caseih.com. That site is somewhat incomplete, but I think it will show that.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
