Re: B-275 Hyd?
Posted by Fromjb2 on August 06, 2007 at 18:10:46 from (74.111.67.38):
In Reply to: B-275 Hyd? posted by Dean E on August 06, 2007 at 17:31:23:
Hi B275 has separate hydraulics and transmission reservoirs. Transmission holds 5 US gal of 80 or 90 wt differential gear oil. Filler plug is by gear shift. Full level plug is on side of transmission case by left brake pedal at the floorboard.
Hydraulic housing holds 3 1/4 US gal of IH Hytran hydraulic fluid. It is filled thru the filler plug behind the seat on top of the 3pt housing. Fill till oil is level with top of housing.
Hope this helps
JimB
