Re: 715 combine
Posted by Duane NC OH on August 06, 2007 at 18:33:21 from (216.255.39.146):
In Reply to: Re: 715 combine posted by El Toro on August 06, 2007 at 11:59:51:
our 715 had a 301D. it is the same block as the 282D that 560's had. only difference is the 301 had no sleeves. we never had any motor problems with our 715. after our 560D cracked a block we put in 301D engine from a 715. it was a pretty forward swap. this engine has not given us any trouble either. still have the 560 but the 715 was happily traded on a 1620.
fwiw
Duane
