Re: Farmall 300 Hydraulics . . . Again . . .
Posted by georgeky on August 06, 2007 at 19:32:26 from (64.12.117.137):
In Reply to: Re: Farmall 300 Hydraulics . . . Again . . . posted by Matt Weltz on August 06, 2007 at 19:15:20:
It may have just stuck after your 20 minute run time. If there is a rough spot in the bore it could be doing this. It almost has to be in that regulator valve somewhere. You might check the saftey valve, as if it is stuck it could build to much pressure and cause the orifice screen to collapse.
