Re: Need help w/ bearing seal
Posted by Bob Kerr on August 06, 2007 at 20:00:28 from (64.12.117.137):
In Reply to: Need help w/ bearing seal posted by ScottyHOMEy on August 06, 2007 at 14:56:21:
Never worked on a BN, but if anything like on an H you are talking about the bull pinion shaft the brakes hook up to? or is it the deal behind the cover like for hooking up the mounted planter.If like on the H, there are two threaded holes in the cage that are for removing the cage only. on an H you have to remove the bull gears first though. The cage has an O ring that makes it hard to get out. Good luck with it.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
