Re: M engine - How would you build it?
Posted by Janicholson on August 08, 2007 at 11:18:01 from (66.173.50.144):
In Reply to: Re: M engine - How would you build it? posted by mark on August 08, 2007 at 09:37:10:
One issue not well discussed yet is duration of peak mean effective pressure. The slow farm tractor is going to have maybe three times as much actual time go by with the pressures as high as they will go. Not only does this lead to detonation, but substantial heat transfer to the exposed combustion surfacs near 3 to 8 degrees after TDC. A auto engine cranking 3 to 4K RPM will have far fewer issues there. I do believe the fuels are way better off with no lead not only for humans, but for engine life and spark plug longivity. Auto engines use vacuum retard/advance controls to make modest fuels work (or today electronic fuel and spark control. The highest efficiency is obtained at the exact point of the beginning of detonation, Just a tiny bit is perfect. Sensors on new engines do this per cylinder in some cases to optimize spark and mix. On an M ---- sorry. JimN
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
