Re: M engine - How would you build it?
Posted by CenTexFarmall on August 08, 2007 at 18:40:44 from (172.136.167.244):
In Reply to: Re: M engine - How would you build it? posted by Janicholson on August 08, 2007 at 11:18:01:
This is a good point to bring up. The M's relatively good rod ratio would be a factor too, I think.
You know, you can add a knock sensor to any engine with a little engineering. I could be used as a tuning aid. You would just have to determine if the gear driven cam and valve train noise would agitate it.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
