Re: 1939 Farmall H won't start
Posted by TroyC on August 08, 2007 at 19:47:28 from (64.252.191.128):
In Reply to: Re: 1939 Farmall H won't start posted by ScottyHOMEy on August 08, 2007 at 16:49:36:
Yes, I've checked the plug wire setup, 1-3-4-2 several times, just in case I had that screwed up.
It does sounds like that.
I don't have a hand crank yet, but ordered one last week. (should be in tomorrow)
I haven't done the compression check yet. I should do that before pulling the valve cover.
It certainly sounds like it should be running. I've spent close to 2 weeks workin with it.
Brand new starter, battery cables, starter switch...
I'll try the compression test tomorrow and let you all know.
