Re: M engine - How would you build it?
Posted by ChadS on August 09, 2007 at 07:40:18 from (4.224.78.52):
In Reply to: M engine - How would you build it? posted by CenTexFarmall on August 08, 2007 at 07:52:35:
281ci, 4.125 bore. 72 hp at 540 with a 8060 head and run on 87 pump gas all day long under a heavy load. Step up to a 450 gas head and be in the low to mid 80s and still run on pump gas, 89 octane to be exact. Now its not a stock set up Im talking about, but, its a stock bore for a 281, and either a 8060 head or a 450 gas head. It still use a 6 volt battery to fire it up. We call this our plow day special engine. Its how I built mine, and very happy with it. ChadS
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
