M engine - How would you build it?
Posted by CenTexFarmall on August 08, 2007 at 07:52:35 from (172.164.227.66):
I'm finally to the point of completely going through one of my M's. Obviously a lot of you have been through this process and have seen different combinations, so I'm looking for some advice. The two candidates I have are a '53 Super M and a '51 M with the 5000 ft. high altitude option (X1-b). The goal is to build a solid work tractor and take advantage of modern parts and fuels to get a reasonable increase in power. I know that I can get sleeves and pistons to make the '51 have the same bore size as the super. The question is which cylinder head to go with. I haven't been able to substantiate from research if the high altitude head has smaller combustion chambers or just more dome on the piston. I haven't pulled that engine down yet to to a physical check of the chamber size. The other factor is if the ports are better designed on the super M head vs. the earlier heads.
I'm thinking of using a 450 camshaft to help with the power increase but not sure what would be the best intake and carb to use.
What would you do?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
