Re: Georgeky and Hugh MacKay..........Iiiiiiii did it! :)
Posted by georgeky on August 09, 2007 at 09:15:42 from (205.188.116.73):
In Reply to: Re: Georgeky and Hugh MacKay..........Iiiiiiii did it! :) posted by Patrick Martin on August 08, 2007 at 23:46:09:
Patrick, new seat springs are available from OEM for about 35 bucks a piece. May be available from somewhere else, but I don't know. OEM 1-800-283-2122
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
