Re: 1939 Farmall H won't start
Posted by C. Amick on August 09, 2007 at 17:24:09 from (66.49.35.161):
In Reply to: 1939 Farmall H won't start posted by TroyC on August 08, 2007 at 16:10:14:
I think its either out of time or a valve is stuck. With the switch off, carburetor remove the air cleaner hose and hold your hand over the inlet of the carburetor and crank the engine over. You should feel a constant vacuum. Is there a way to loosen a bolt and rotate the mag without having to remove it in order to change the ignition timing a little? I know that some mags have a slotted mounting hole.
