Re: Tachometer cable dosn't turn. C135 engine 2404 tractor.
Posted by K.B.-826 on August 09, 2007 at 22:36:33 from (68.115.104.106):
In Reply to: Tachometer cable dosn't turn. C135 engine 2404 tractor. posted by HughB on August 09, 2007 at 18:04:51:
Common problem. The little plastic gear in the tach drive is stripped out. If you know that the tach itself is good, and since you've got a new cable, it will definetly be cheaper to repair rather than convert to an electric set-up.
