Re: M vs Super M
Posted by NDS on August 11, 2007 at 12:01:18 from (64.12.116.73):
In Reply to: M vs Super M posted by Erwin on August 11, 2007 at 10:00:14:
Do not have a clue about what it is worth but I have a M that came free several years ago and had no major problems and I still have over $2000 in it . New tires, carb overhaul kit, dist. overhaul, wiring, battery box, seat pan, bushings and spring, muffler, sediment bowl and the list goes on. So if SM does not need anything in may be cheap.
