Great Deal On A Super M???
Posted by City-Boy McCoy on August 11, 2007 at 06:55:45 from (68.221.167.124):
Howdy, Boys:
Ebay Item #140146287193; Now here is an example of what I would call a good deal on a Super M. It has a LOT to offer, to wit: Stage II, all 4 new tires, newer style IH wide front end (stronger and turns sharper), Saginaw dual cylinder 3-point hitch (the best), new remote valve, straight sheet metal and all gauges work.
Let's do the math: Typical rusty Stage II Super M goes for around $2,200+/-. Now, let's get it up to this same condition: Add new tire cost: $1,000; add IH heavy duty wide front: at least $400; Add new Saginaw 3-point (with freight): $800; Total: $4,400.
Minimum bid: $2,750. NOBODY BIDS!
Yet, they practically fist-fight over a $1,400 tired out M emitting blue smoke, with old cracked tires, belly hydraulics and nothing but a welded up draw-bar.
I can never figure out these ebay bidders.... Fascinating.
mike
