Posted by Wardner on August 12, 2007 at 13:31:43 from (4.154.244.29):
In Reply to: international i-4 posted by dennis vanpopering on August 12, 2007 at 11:52:51:
If your I-4 still has the spring loaded pintle hook, Harold H and myself would appreciate your taking some measurements on the lower arms (struts). Specifically the following measurements:
dimension of bar stock
bolt diameter where bar attaches to pintle receiving casting
overall length from end of bar to end of welded pipe section (hinge).
Now to your question. Bore size was increased when the Super H was built. You have a later tractor or motor. Bore on that same basic motor was increased again when the 350 was built. Send us the serial number of the tractor and also look for cast numbers on the block above the oil filter. The number should begin with a C.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
