Re: Farmall B - timing the engine when...
Posted by teddy52food on August 12, 2007 at 15:51:53 from (204.73.107.177):
In Reply to: Farmall B - timing the engine when... posted by Dave H (MI) on August 12, 2007 at 14:26:51:
I think you are working with a distribtor. if so, 90 degrees off and it won"t run. Take out the 2 5/16 bolts (1/2 inch wrench) and pull the dist out. there is a gear on the end. examine this gear and see if it looks like the teeth are stripped. If not then turn the rotor so the metal strip is pointing to # 1. Put it back in and put the bolts in just loose enough so you can still turn it. Then watch the points as you turn it back and forth. Stop when the points are just breaking and tighten the bolts. Try starting and if it fires in the exaust and doesn"t try to run, you are off 180 degrees. Just swap the wires across from each other and try again. Fi it still won"t start, pull the cap and get the flywheel mark lined up. then look at where the rotor is pointing. It should be on # 1 or # 4. If not you have gear problems. Let us know what you find.
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
