Farmall B - timing the engine when...
Posted by Dave H (MI) on August 12, 2007 at 14:26:51 from (205.188.116.73):
Got the valve situation squared around and I DID find those marks after I used the wire in the cylinder trick. My instructions for timing the engine say that the rotor should be pointing roughly to the #1 spark plug wire when at TDC for #1. FIRST> Which side of the rotor? SECOND> Neither side points at the #1 plug wire. Is there something I should do or should I just follow the instructions and loosen the distributor, rotate about 30* clockwise past the #1 mark and then turn it back to get a spark from the coil wire. Sorry, I am typing fast here. There is a post from me on page 2 of this forum that has the instruction I am reading from. Main point of confusion I have is which end of rotor and what to do about it pointing in the wrong direction....hope that makes sense.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
