Re: IH carb stuff
Posted by CNKS on August 12, 2007 at 17:36:16 from (204.249.178.32):
In Reply to: IH carb stuff posted by noidea on August 12, 2007 at 13:29:56:
The Super H/Super M -- up, including the 460/560 have the adjusting screw 5 turns out for max power. I think they were used until solenoids replaced the adjustment, perhaps the 706/806. Other than dirt getting inside you probably don't need the screw. It can be turned in for better economy where less than max power is needed. You should get the correct carb for your engine.
