Re: Farmall B - timing the engine when...
Posted by georgeky on August 12, 2007 at 17:49:11 from (64.12.116.73):
In Reply to: Re: Farmall B - timing the engine when... posted by Dave H (MI) on August 12, 2007 at 15:12:41:
Just do like Teddy said. It may take a try or two to get it to sit where you want it to. I assume since you are at TDC and you did find the timing mark it is not 180 out. But if so just start over and find TDC again and move your distibutor 180 and try it again. This is fairly simple once you catch on to it.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
