Re: Farmall B - timing the engine when...
Posted by Dave H (MI) on August 12, 2007 at 15:12:41 from (205.188.116.73):
In Reply to: Re: Farmall B - timing the engine when... posted by georgeky on August 12, 2007 at 14:40:38:
That is what I was thinking. Can you give me an idea of what to do with it. Presuming that I need to rotate the whole thing to get it pointing correctly BUT don't want to step in over my depth so I will wait for some instruction.
I am assuming that the side of the rotor that should be pointing to #1 is the side that would contact #1 if the cap were on. That being said, the rotor is about 90 degrees off. I could use some instruction on the best way to correct this situation. Would it normally have run at all in this condition? Thanks guys!
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
